It sounds like either you have a large vacuum leak, or the fuel pressure is too high. Have you ever noticed any black or gray smoke from the exhaust?
Do me a favor. I need you to check for diagnostic trouble codes. The truck has an OBD1 system and doesn't require a scanner to retrieve codes. All you will need is a short jumper wire or even a paper clip. Here is a link showing how it's done:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Try that and let me know what you find. Also, please confirm the engine size. There are several different V8 engines that were offered.
Take care and I'll watch for your reply.
Feb 16, 2022 at 5:33 PM
