OBD2 port does not want to communicate with any scanner
2001 AUDI TT
130,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
MIKHAIL17
Hi, the OBD2 port on my vehicle doesn’t want to communicate with any scanner.
So far, I already checked all the fuses and everything seems to be good without any break, I reset the ECU but still no link on the scanner. I ended up testing each pins with multi-meter with back probe method and found out that pin 7/ K-line only have .07 Volts running when it suppose to have way more than that. Do you guys know how to trace a short on K-line to ECU. I'm a beginner in electrical experience with car. Any tips and advice will help. Thank you
Nov 3, 2019 at 2:57 AM
MIKHAIL17
This is the Pin 7 for K-Line.
Nov 3, 2019 at 3:00 AM
MASTERWRENCH
  • 258 POSTS
You are correct, pin 7 is the K-Line diagnostic circuit. The best way to narrow down a short on the network is to start by unplugging modules one at a time to see if communication resumes. Attached are several diagrams showing all the modules on the communication bus along with the locations of these modules in the vehicle.
Nov 3, 2019 at 7:16 PM
MIKHAIL17
Thank you so much sir, you are a legend.
Nov 3, 2019 at 9:42 PM
MASTERWRENCH
  • 258 POSTS
You're quite welcome!
Nov 4, 2019 at 4:28 AM
