Hi again.
Well it sounds like there is possibly a problem with the fuel pressure sensor/regulator circuit or the sensor itself. However it is important to get more information about your replacement ECU, where did you buy it and how did you have it programmed? If it is a used unit then there is a fairly high likelihood that that can be the cause of your issue. Do you know what codes/symptoms you had in/with the original ECU?
That information would be greatly helpful in narrowing down your current problem, if you have all or some of the original symptoms/codes then we need to look somewhere other than the ECU, if these symptoms/codes are new I would be highly suspicious of the replacement ECU provided it was properly installed and no damage occurred during the installation process.
If you could give us as much of this information that you have we will be able to guide you more efficiently.
Jan 28, 2020 at 5:07 AM
