The P0752 is related to a shift solenoid in the transmission. There are two different transmissions. One indicates an issue with the 1-2 shift solenoid and the other is a shift solenoid valve issue.
The P0700 is more of a generic code. It indicates the transmission control module (TCM) identified an issue that can cause emissions-related concerns.
The P0014 is tied into the camshaft position sensor indicating it is over advanced.
So what does this all mean? I need more information. Is there a shifting problem? are there any drivability issues you notice as far as power, starting, or anything specific to the engine?
The transmission code (752) should be noticeable. Likely, it has a delayed shift or not shift between certain gears.
Dec 27, 2020 at 11:06 PM
