OBDport has no power
2006 BUICK LA CROSSE
182,000 MILES
DENALIWONTSTOP
  • 6 POSTS
The OBD port is getting no power. The fuse for the cigarette lighters is still good.
Aug 12, 2018 at 2:19 PM
Good afternoon.
The DLC is powered by its own fuse in the inside fuse block in the car. Check for the fuse block on the end of the dash when you open the door. You have to pull off a cover.
I attached a wiring diagram for you to view on what it says for the fuse.
What concerns me is why it failed. Fuses blow for a reason. If you do not find the reason it will continue to fail.
Aug 12, 2018 at 3:32 PM
DENALIWONTSTOP
  • 6 POSTS
I have a different diagram for the fuse box on the end of the dash for a 2006 Buick LaCrosse.
Aug 13, 2018 at 2:59 AM
DENALIWONTSTOP
  • 6 POSTS
I attached pictures of the diagram and the fuse box. Thank you.
Aug 13, 2018 at 3:01 AM
Did you use a test light and verify power to fuses and power on both sides of the fuses?
Aug 13, 2018 at 3:23 AM
DENALIWONTSTOP
  • 6 POSTS
Yes sir, even put a new one in it.
Aug 13, 2018 at 3:35 AM
New one in what? Did you check for power on pin 16 of the DLC?
Aug 13, 2018 at 3:39 AM
DENALIWONTSTOP
  • 6 POSTS
New fuse under the hood and yes sir.
Aug 13, 2018 at 3:54 AM
The fuse is not under the hood it is in the interior fuse block as listed.
Did you verify power on all the fuses on both sides?
Aug 13, 2018 at 3:58 AM
DENALIWONTSTOP
  • 6 POSTS
I changed the cigarette lighter fuse under the hood, but I do not have the DLC fuse on the diagram.
Aug 13, 2018 at 6:51 AM
Again, the cigarette lighter fuse is not the fuse.
It is the OnStar fuse in the interior fuse block as indicated in the diagram.
If you have power on both sides then you have a wiring issue between the fuse block and the DLC.
Aug 13, 2018 at 7:53 AM
