It was working after plugs in scanner it won't turn on. Check all fuses all are good. Where is the fuse location for the OBD port?
Apr 28, 2024 at 2:17 PM
FRANKBASSOO
MEMBER
1 POST
Where is the fuse location for the obd port
Apr 28, 2024 at 2:23 PM
STEVE W.
CERTIFIED EXPERT
Okay, so it was okay, then a scanner was plugged in and now there is no power at pin 16, correct? That is fed from fuse 1 in the passenger side fuse block that also is a power feed to the large data connector under the hood. FYI, if you want access to all of the modules on that car you can use a scan tool that can connect to the 38-pin connector under the hood. The one under the dash only gives you drivetrain diagnostic info.
