Obd issue?
2013 BMW 335
118,000 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I scanned it before, and it was fine. But now I am trying to find out why the battery drains if i leave it parked 3 days or so, especially if i use the fob to lock it. Battery has been replaced, but not an agm battery. I checked all the fuses under the hood, in the trunk. I cant find any fuses inside the car on either side. This is a 335 so they are maybe different, nothing behind the passenger kick panel. I took down the obd connector and it looks fine. Where should power be going to on the obd? And i want to apply power to it to see if it starts to work using the probe tester will that work? Only obd i saw marked based on online checking is one under the hood. In the trunk the fuses are under the cargo carpet towards the inside.
Mar 27, 2025 at 10:50 AM
Yep, the data port connector needs power. Here is a video that should help:
https://www.youtube.com/watch?v=6Tlg3JmgNSQ
The port is powered by the fuse # 75 in the fuse panel under the right side of the dash.
Mar 27, 2025 at 12:32 PM
