OBD II port not working
2011 JEEP LIBERTY
130,000 MILES • 2.4L • V6 • 4WD • AUTOMATIC
KASHARRA
Can you please tell me which fuses I need to check? Thank you!
Jul 1, 2022 at 10:14 PM
I would check fuse m30 in the TIPM under the hood here is a guide to help you and the fuse location in the diagrams below, I have also included the wiring diagrams for the ALDL connector so you can see how the system works.
Jul 2, 2022 at 5:05 PM
KASHARRA
Thank you! I tested the one connector at position 16 and no power. I checked every single fuse and no luck. I think it's the harness. Bummer.
Jul 2, 2022 at 8:03 PM
Can you check for power at the m30 fuse? if there is none then it is probably the TIPM which is a common failure but easy to fix with a new unit because it self initializes, here is how to change it out. Check out the diagrams (below). Please let us know what happens.
Jul 3, 2022 at 12:20 PM
KASHARRA
There was power at the fuse. I had to trace the wire and found corrosion and a break at a soldered connection under the driver's floor mat. Now it works! Woohoo! Thanks so much for the help. The wire was white with red stripe.
Jul 3, 2022 at 3:09 PM
Nice work! Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help. Can you please leave us a rating? (Copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Jul 5, 2022 at 11:50 AM
