Hello James,
These codes come up when the EGR valve or ports that feed the valve are clogged or the valve is not working, I would remove the EGR and use a flashlight it inspect the ports also while the valve is off. use this video to test the valve. Also check the vacuum line to the valve:
https://youtu.be/DqUCbbKdWf4
Here is the location of the valve in the images below. Please let me know or upload images of the problem.
Feb 19, 2023 at 9:42 AM
