It said idle air valve bad . So do I have to replace the ECM to?
Apr 28, 2017 at 1:00 PM
HMAC300
CERTIFIED EXPERT
before you make the repair pull the ECM cover off and if you see a burnt spot then it is fried and you need another which is rebuild able. however, they have to be programmed to your car for security and a mechanic has to do it. it is quite common on this car.
