No communication?
2001 FORD F-450
100,000 MILES • 7.3L • V6 • 4WD • AUTOMATIC
OLDTH
I believe the scanner will read both OBDII and CAN but not sure.
Nov 17, 2019 at 5:53 AM
I attached the diagram of the data link connector.
Pin 16 needs power and 4 needs to be grounded.
Pin 2 and 10 are the serial data lines that communicate with the modules. Use an ohmmeter across 2 and 10 and you should have 60 ohms.
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Jan 7, 2021 at 2:36 PM
