Hello, hope y'all enjoying Labor Day Weekend!!
I was driving around the other day and my check engine (MIL) light came on and stayed on. So, with my very basic knowledge, I decided to get an OBD 2 Scanner on Amazon and go DIY. I got a cheap scanner Motopower MP69033 ($25!!) and plugged in to the OBD 2 port under the steering wheel and it powered up fine using the car's power. Kept ignition in the "on" position before that per the instructions. It has a VIN button. When I clicked on it, I tried to scan but said "connection failed". I also hit the "DTC" button on the scanner which I believe should throw the error codes back at me but again same message "connection failed".
Before I can blame the cheap Motopower scanner, could it be that there's no power coming from the Audi's ECM?? perhaps to the OBD port. Maybe it's a fuse issue.
Is there like a certain quick thing you can suggest that I can check and make the scanner retrieve the codes?
Appreciate Ya'll help!! Cheers!
Sep 4, 2022 at 4:33 AM
