O2 spacers/simulator
2008 HYUNDAI TIBURON
95,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
DKIN
What kind O2 spacers/simulators should I use on my vehicle listed above GT to get rid of my catalytic converter?
Mar 22, 2021 at 11:56 PM
STEVE W.
  • 15,113 POSTS
Removal of the converter is a crime in all states. Also it's removal will cause multiple engine codes and render it undriveable due to a lack of fuel control from the ECU based on the O2 sensor output response. What is the issue with the converter that makes you want to remove it? A code set or failure? Repair or replacement depends on what area you live in, some places require the replacement parts to be certified while others only require them to be functional.
Mar 23, 2021 at 3:23 AM
DKIN
I live in Arkansas and there are no emissions laws nor are there inspections. I'm only using it as a track car. I know smell eggs when I really get on it so that must be the catalytic converter getting plugged. I don't see point in getting headers when I can just get rid of the catalytic converter or rather get rid of what's inside it. Overheating before I'm on here earlier some kid was having problems with his car vacuum leak or something however he had mentioned that he did the same thing I did and and got o2 spacers for the sensors after the catalytic converter. If they made vehicles the way they used to I wouldn't have to worry about spacers, but nowadays you can't do anything to a car without having to end up doing something else do it. I was just wondering what kind of spacers that other gentleman used on his Tiburon. It would save me a lot of time and money. I've been looking up the spacers online however I'm not too sure which one to get considering I've never use a car over the year of 1992 on the track. I know the car has a lot more power, it just needs to breathe but I also don't want any codes to come up that will take away horsepower. If anyone could help me figure this out I would be very grateful. I usually mess around with older Honda Civic like 1990-1991 and older z24 Cavalier. And I know some tricks for Civic and Cavaliers regarding torque as long as they're standard if your interest I'm more than willing to share some info. Thanks for your time hopefully someone can help me out, lol.
Mar 23, 2021 at 8:06 AM
STEVE W.
  • 15,113 POSTS
The issue isn't a state one it's federal. It is a violation of the Clean Air act and now they are pushing to make even race cars illegal if they were ever a street car. Because of that it makes it hard to give out any information as the feds are also trying to make pretty much any parts that alter the emissions an illegal item.
Stupid, but it's the feds so a typical cluster.
More info and a way to help.
https://www.semasan.com/legislative-alerts/national/save-our-racecars-san-challenges-epa-court
https://www.sema.org/news-media/enews/2021/10/sema-continues-fight-protect-motorsports-parts-businesses-and-racers
Mar 23, 2021 at 11:36 AM
I-SMOGEM
  • 118 POSTS
Hi Dkin,
Your words: "I'm only using it as a track car." Vehicles that are "not" used on public roads and highways can have a variety of modifications to enhance performance that are not street legal. The list is never-ending.
Your specific issue is by using your vehicle "on the track", you are overloading the catalytic converter with fuel, causing it to overheat and make sulfur oxides (SO2 and SO3) giving you the rotten egg smell. What I'm going to say below and doing it to a vehicle driven on public roads "Is Illegal" -- everywhere!
What you are going to do is either completely remove the cat or hollow it out and leave the shell. Remove the before and after the cat O2 sensors for either procedure so you do not damage them. Do not remove the install holes for the O2 sensors both before and after the cat because the sensors are going back in them. Once you have done that, get spark plug spacers. These are designed for engines that use oil and reduces the chance of a spark plug being oil fouled making the engine run better longer.
These spacers will be used for the 'after the cat' O2 sensor and basically fooling the computer thinking it still has an efficient cat thereby not setting a code. Do not do modifications to any other O2 sensors as it will definitely cause performance issues. The after the cat O2 sensor only checks cat efficiency and is not used for fuel metering.
Check this YouTube video about it:
https://www.youtube.com/watch?v=xpvpyBSqbMg
Happy Racing. Glenn
Edit add on: I stopped doing Smog Checks about 2008 and the above procedure was common (though never admitted to). "If" the EPA has made issues with modifications now on track vehicles, use your own judgement. But, I've never seen or heard of an inspector at any track. Safety inspector -- yes. EPA inspector -- no.
Mar 23, 2021 at 12:37 PM
