Whole problem started with lean codes on both banks.
Replaced fuel filter.
Looked for vacuum leaks.
Cleaned MAF.
Then I noticed, all four O2 sensors read .020 volts Flat, no change.
Changed two upstream O2 sensors.
Still no response.
Checked O2 sensor heater power, good.
Ran truck for 5 minutes O2 sensors began working.? I assume they got warm from exhaust gases
This morning, O2 sensors working, got out on highway, after 20 minutes they flat lined, constant .025 volts.
Engine goes into Closed Loop Fault.
When I got off highway, one O2 sensor begins working and engine reports Closed Loop.
I am lost. Any help?
Truck has sat for 2 hours, started it up, O2 sensor bank2 comes on line, truck reports fuel system in CL. about 2 minutes later O2 sensor bank 1 comes alive. Very hard to start.
Cleaned MAF.
Still no response.
Mar 15, 2021 at 6:59 AM
