Can I get a diagram of the upstream and downstream O2 sensors?
2005 CHEVROLET MALIBU
250,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
RAIKIRIR2
Can someone show me a detailed diagram of the upstream and downstream O2 sensors and where they plug in after installation?
Nov 8, 2023 at 8:39 AM
There are two sensors. One is a pre-catalytic converter sensor (upstream) and the other is a post-catalytic converter sensor (downstream).
If you look at pic 1 below, I highlighted the upstream sensor and connector location. Note that the sensor is in the exhaust manifold and requires the removal of the exhaust manifold heat shield. Pics 2-7 are the directions for removing and replacing the upstream sensor.
If you look at pic 8 below, I highlighted the downstream sensor and connector. The remaining pictures are directions for the removal and installation of the downstream sensor.
Here is a link you may find helpful. It explains in general how it is done, and the pics are a little more helpful. LOL
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
joe
See pics below.
Nov 8, 2023 at 8:00 PM
