O2 Sensor preventative replacement
1997 TOYOTA CAMRY
170,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JAY_SANCHEZZ15
  • 45 POSTS
I would like to replace the oxygen sensors as preventative maintenance. No Check Engine Light.
I purchased the car from a guy in California and I believe this car has 2 O2 sensors and 2 Air Fuel Sensors following California emissions requirements.
How can this be confirmed?
Should I get these OEM or from places like AutoZone/O’Rielly/Amazon?
I have seen them much cheaper on Amazon using part numbers from Toyota Parts OEM.
However, I have heard you need to buy California Approved emissions O2 sensors if it’s made in California, but I live in Minnesota where there is no emissions test.
However, I would still like the vehicle to run as optimally as possible even if it means buying California O2 or A/F sensors.
Not quite sure how to go about this.
Jan 2, 2020 at 5:25 PM
Good evening,
You can look at the emission tag under the hood. It is a white tag. It will say either it is federal or California emissions.
Get OEM sensors. Aftermarkets are not exact and can effect the way it runs.
Jan 2, 2020 at 5:52 PM
