There are checks to be done as the sensors may be working but seeing bad information.
Below are the possibilities for all the codes. All these items need to be checked to be sure of the reason for the codes.
The odds of having four sensors fail at the same time is like you getting hit by lightning two times in one day.
P2196
Descriptor
O2 Sensor Signal Biased/Stuck Rich - Bank 1, Sensor 1
Probable Causes
Air Leaks After Mass Air Flow (MAF) Sensor
Camshaft Timing
Corrosion
Cylinder Compression Incorrect
Diaphragm or Exhaust Gas Recirculation (EGR) Vacuum Regulator Leaking
Engine Oil Dipstick Seated Incorrectly
Evaporative Emissions (EVAP) System Purge Valve Stuck Open
Exhaust Gas Recirculation (EGR) Valve Malfunction
Exhaust Leaks Before or Near Heated Oxygen Sensor (HO2S)
Gasket Leaking
Harness Connections Incorrect
Harness or Heated Oxygen Sensor (HO2S) Short to Voltage
Heated Oxygen Sensor (HO2S) Circuit Open
Oil Overfull
Positive Crankcase Ventilation (PCV) System Leaking or Valve Stuck Open
Powertrain Control Module (PCM) Damaged
Universal Oxygen Sensor Pumping Current (UO2SPC) Circuit Open
Vacuum Leak
Water in Harness Connector
Apr 14, 2021 at 12:08 PM
(Merged)
