Yes it could.There is a pick up in the tank with a hose. If the hose is cracked, it will suck air instead of fuel when it gets uncovered.
I would remove the fuel pump and inspect for any damage or leak from the pump assembly.
1. Relieve the fuel pressure.
2. Remove the fuel fill cap.
3. Remove the seat cushion.
4. Remove the access panel (A) from the floor.
5. Disconnect the fuel pump 5P connector (B).
6. Disconnect the quick-connect fitting (C) from the fuel tank unit.
Oct 12, 2018 at 5:48 PM
