O2 sensor location needed
2005 BUICK TERRAZA
45,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
GONZALO AGUDELO
where are the O2 sensors located?
Oct 11, 2020 at 5:59 PM
I attached a pic below. See if it helps and let me know if you have questions.
This guide can help you step by step to change out the sensors:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Oct 11, 2020 at 6:28 PM
GONZALO AGUDELO
Thanks very helpful Question did I need to change both?
Oct 14, 2020 at 2:50 PM
First, you are very welcome. As far as replacement, the diagnostic trouble code that was retrieved should indicate which one is the issue. By any chance, do you remember what the code was that was found? In most cases, both do not need replaced at the same time.
Oct 14, 2020 at 6:52 PM
