O2 sensor DTC P0031
2003 TOYOTA TUNDRA
126,500 MILES • 3.7L • V6 • 4WD • MANUAL
TESMONDH
Getting this code in my pickup. I need help determining which sensor it is and if I can change it easily myself or if I need to take it to a mechanic. My pickup is an SR5 V6 3.
May 10, 2017 at 3:15 AM
STEVE W.
  • 15,113 POSTS
P0031 - Heater control circuit low (bank 1 sensor 1). Easy item to test, unplug the sensor connector for the upstream O2 on the drivers side. Look at the connector and you will see two wires that are the same color and two that are different. The two same color wires are the heater circuit. Those carry twelve volts to the O2 sensor to make it heat up and respond faster. Use an ohm meter to check for continuity between those wires. Also use a test light to see if the twelve volt feed is there as well.
May 10, 2017 at 5:23 AM
TESMONDH
Is the B1S1 sensor located beneath the rig or under the hood?
May 10, 2017 at 5:39 PM
STEVE W.
  • 15,113 POSTS
It is the first sensor in the exhaust pipe. On the V8 it's in the manifold, in the V6 it's in the pipe just above the convertor.
B1 means it is on the side where cylinder number one is. S1 means it is the first sensor in the system.
May 11, 2017 at 4:26 AM
TESMONDH
So, the catalytic converter is on the passenger side near the door underneath the rig...the sensor would be the first sensor in front of the converter, nearest to the engine?
May 11, 2017 at 5:29 PM
STEVE W.
  • 15,113 POSTS
Yes BUT there will be a Y pipe coming from the convertor to the engine. In that pipe or in the exhaust manifolds themselves there will be a sensor on each side you need to be sure you check the sensor that is on the side where cylinder number one is. That will be B1 S1
May 11, 2017 at 9:35 PM
