I'm getting the code P0159 with a faulty 2-3 O2 sensor issue. Where is this sensor located on my car and what does those numbers mean?
Jan 11, 2016 at 7:40 PM
HMAC300
CERTIFIED EXPERT
it's the O2 sensor on rh bank after converter
Jan 12, 2016 at 6:27 AM
ENOCHSAMRAJ
MEMBER
Thank you for your response
Jan 15, 2016 at 8:19 PM
MHPAUTOS
CERTIFIED EXPERT
Reset the code and see if it comes back. If the code comes back, the problem is more than likely the rear passenger side oxygen sensor. Check for any exhaust leaks make sure that the wiring is intact and the plug for the sensor is not damaged If you have a scanner with live data check that the sensor is creating voltage check for vacuum leaks as well.
