Codes P0158 and P2096
2007 DODGE MAGNUM
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
UNISYS1
  • 4 POSTS
I replaced Bank1 and bank 2 o2 sensors aft of converter. When I checked system with my scanner the first time code 0158 came up again. Checked all vacuum lines and wiring I could not find any defects. Replaced gas cap and air filter. Checked scanner again now I have 2 codes P0158 bank 2 sensor 2 and P2096 fuel system too lean bank 1. Any help would be appreciated.
Mar 20, 2021 at 2:57 PM
Since you are getting lean mixtures, chances are either you have a vacuum leak (which you have checked), low fuel pressure, or even an exhaust leak before the catalytic converter.
First, here is a link explaining how to locate a vacuum leak:
Next, here is a link that shows in general how to check fuel pressure:
Here are the manufacturer's specs for fuel pressure:
2007 Dodge Magnum V6-3.5L VIN V
Fuel System Pressure
FUEL SYSTEM PRESSURE
400 kpa ± 34 kpa (58 psi ± 5 psi)
__________________________________________
Mar 21, 2021 at 7:42 PM
