location of the post-cat lambda sensor
2007 VAUXHALL CORSA
67,000 MILES • 1.2L • 2WD • MANUAL
GRINDLE123
I had my EML come on a while back so I bought an OBD II scanner so I could find out what was causing the light to illuminate. The code was P0131 which is the O2 Sensor, Bank 1 Sensor 2. I replaced the sensor under the hood right by the engine but the light stayed on. i have been reading up quite a bit, but no where online can i find the location of the post-cat lambda sensor? Could someone please help.
Sep 22, 2016 at 2:55 PM
GRINDLE123
p0141. sorry.
Sep 22, 2016 at 3:24 PM
JIS001
  • 3,412 POSTS
We do not have that vehicle here in the United States but that sensor will either be on the catalytic converter or right behind the catalytic converter. So you will need to raise the vehicle up and inspect the around the catalytic converter area. Hope information helps you and let us know how you do.
Sep 22, 2016 at 5:35 PM
