Car will give these codes and go into 'limp mode' run rough and die...will not restart unless power removed from ECM to clear and codes will return within 5 miles run rough and die...unable to clear with handheld code reader...Mechanic said O2 heaters and circuits fine...So i purchased refurbished 'plug and play' ECM from ebay...got new codes P1189 & P1105 for TIP sensor and solenoid...TIP sensor is new so online company sent me 2nd ECM which gave new codes of P0700 & P0755- not communicating with Transmission and car would not shift from first gear...so online company sent me 3rd ECM which gave P0032 & P0038...They refunded ALL my money...Now purchased ECM from different online company and getting P0032...
What I have Done:
-Swapped ASD relay with horn relay...
-Unplugged Sensor 1 and measure 3.6 ohms heater resistance with no short to ground and only 9.5 Volt supply? Supply ground is good and Hot wire is 2.8 Ohms to ground???
-Unplugged sensor 2 and measure 4.3 ohms heater resistance and 10.7 Volt supply...Supply ground is good and Hot wire is open to ground...
Any assistance on my next step is greatly appreciated.
What I have Done:
Mar 17, 2016 at 10:25 PM
