Hey AMIT KUMAR GOND,
Have you had a transmission service recently?
The first thing to do is to check the transmission oil level and condition.
There will be instructions in your owners manual on how to check the oil level.
Generally you check the level with the engine at operating temperature, vehicle on level ground, engine running in park. On the dipstick the oil level should be in between the cross hatched area on the dipstick. if it is below or above or the oil looks dirty/cloudy then you will need to look into changing the oil and filter or adjusting the oil level.
If the transmission oil filter has not been replaced this will need to be done first before further troubleshooting.
Regards, Joe
Apr 14, 2019 at 8:04 AM
