Overdrive light flashes
2005 FORD F-150
155,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
KCCKWILSON05
Overdrive light flashes after hard shift from first to second gear.
Dec 15, 2018 at 6:41 AM
This sounds like you have a shaft speed sensor that is out. Does the speedometer work? If not here is the location of the vehicle speed sensor. If so we should run the codes
Dec 17, 2018 at 3:46 PM
MORTOX
Service Engine light is on - reporting 2 sensors running lean. been on for awhile
Overdrive light came on and starting flashing couple days ago.
today the transimission started slipping and you can hear a grinding noise when going into i think 4th? if i turn on overdrive it doesn't slip.
The PCM module was replaced a couples years ago.
The transmission was rebuilt about 1 1/2 to 2 years ago.
Ant ideas if the transmissions may be at fault or maybe the PCM or exhaust may be causing the slipping?
Oct 19, 2019 at 10:12 AM (Merged)
MERLIN2021
  • 17,250 POSTS
If you hear a grind when it shifts, you do have a tranny problem, the lean condition can be any type of vacuum leak that allows unmetered air into the intake maniflod, or a weak fuel pump.
EDWARD BORGES
I start the motor then the light of check engine go on and the same time the overdrive light start to flash I try to put to drive she dosent move
there is a malfunction in the trans.
check the fluid first. beyond that, you will need a shop to see. if you lost all gears, then you may have lost a torque converter.
a shop will confirm.
JESSE
2000 Ford F 150 symptoms: 1st heard a dragging noise followed by dying at intersection, the OD light flashing off then the check engine light came on. After backin up into a parking space, started dying when trying to put into gear...
If the light is on, you need to have the computer scanned for trouble codes. The trouble code will direct you to where the problem is coming from.
JP1683
seems like its straining when i hit 60
is there something i can do?
i don't haul anything
f150 2 door pick up
43,000
2003
made in mexico
KNIGHTRIDERKITT2000
  • 93 POSTS
sounds like it is not kicking into overdrive, hence the straining, and the light, i would take to the dealership or a close reputable transmission shop, to diagnose your problem, could be something as easy as a sensor.
B. SILVA
hello i have a f150 2001 crew cab and my check eng. recently came on and now when i turn my truck on, my over drive on/off light flashes and it starts to tug. i have to stop and restart my truck to reset the overdrive and then it good.
When the lights are on, have the computer scanned to identify trouble codes. Most part stores will do it for free.
TAZAPPY
We just purchased a 2001 Ford 150 Crew Cab from a dealership. It has 35,000 actual miles. We noticed a a raspy noise that sounded like rotors rubbing on front tires and pedal seems to vibrate when giving gas at lower speeds but after you get over 30 seems to stop. But you can hear a noise off and on while cruising below 30 at times. They explained that it was a noisy motor that checks the brakes and there was nothing wrong with truck. The only way to get rid of noise is replace motor which would cost us $500. Now tonight on the way home from town about 4 miles out of town with truck set on cruise the overdrive light on shifter came on saying off. and it kept flashing off. I kept pushing button to turn overdrive on and it wouldn't work so I pulled over turned truck off and restarted took off again and after setting cruise 2 miles down the road overdrive went off again and light started flashing. Any ideas what this could be. Dealership told me no warrenty except 30 days 50/50 pay on transmission & engine. Thanks for replies. Tammy
Oct 19, 2019 at 10:13 AM (Merged)
JON BOY
  • 4 POSTS
If the overdrive off light is blinking, then the computer has an error code stored for transmission malfunction. You need to get to the dealership or tranny shop for someone to pull the code for you. Hopefully the code will let you know specifically what the problem is
good look.
ANTONIO MIRANDA
My transmission overdrive light doesn't work. It's a 99 F-150 . What do I need to fix it?
Oct 19, 2019 at 10:14 AM (Merged)
Is the OD working? If not, have the TCM scanned to identify where the problem is coming from. If the OD is working, chances are the light in the switch is bad. If I recall, the bulb isn't replaceable. The switch would need replaced.
DYNAMICSAB1
the transmission overdrive light on shifter flashes after driving for 10 min. It resets its self after every start up. why is it flashing.
VEGASFARMKID
  • 30 POSTS
that is your transmissions way of telling you something is wrong, like a check engine light. some local part houses and/or repair shop should be able to read the codes.
BIGBOY92
what causes the overdrive light to blink on my 1997 ford - F150
CUP1981
  • 133 POSTS
It means there is an electrical problem withing the transmission -- failed solenoid, TCM error or wiring issues. Have it evaluated immediately, as driving it in this condition may cause serious damage.
GMM
hello, my eod (electronic over drive) light is flashing and the speedometer/odometer are not working. what would be the cause of this problem? thanks in advance for any help.
BMRFIXIT
  • 19,053 POSTS
tranny need to have the codes read most likely it slipping
scan the TCM for codes
FLEXY5
  • 512 POSTS
Check the speed sensor. It is either located on the tailshaft of the trans or on top of the rear differential housing. If the computer can't sense speed, it won't feed info to the speedo/odometer and it also won't know when to shift. O/D light will probably flash a P0500 code, but check to be sure.
JEFFEY2
i was driven home the other night when i had noticed that my overdrive off light was flashing,i tried to push the button to turn it on but it would not.what could this possiply mean?
thank you for your time.
jeff.
BLUELIGHTNIN6
  • 16,542 POSTS
This indicates that the computer has noticed a fault in the transmission. This could be a sensor, shifting solenoid or something internal. You will need to have a diagnostic scan on your tranny to pinpoint the culprit.
Thanks for using 2CarPros.com!
JP1683
f150 2 door pick up
CHEVY22
  • 1,375 POSTS
depending on what engine and trans are in the vehicle ,
most of the time it is internal , od clutches burned , possibly valvebody gasket if its a small engine with the 5r55e or 5r55s 4r70w have other issues
LAURBUNCH
I have a 1996 Ford E150 conversion van. I just had the transmission pan gasket replaced and the fluid replaced no problems noted. Now after the van has been driven about 15 miles the override off flashes on the shifting handle. Once the car is turned off and started back up the light is off but comes back on after about 15 miles again. No leaks in the transmission but a little bit of a whinning noise if going under 40 MPH.
We have a manual overdrive. Fluid level is fine, don't know what type neighborhood mechanic did repair. Filter not changed. Transmission tune up?
SERVICE WRITER
  • 9,123 POSTS
Thank you for the donation.
Was the filter also changed?
What fluid was used?
Did you recheck the level?
Can you get the codes pulled from the computer?
