overdrive light flashing?
1999 FORD EXPLORER
203,306 MILES • 4.0L • V6 • 4WD • AUTOMATIC
CDERIDDER
what cause the over drive light to flash?
Jul 25, 2017 at 6:28 PM
HARRY P
  • 2,292 POSTS
When a Ford over drive light flashes, it is telling you that there is some sort of issue with the transmission. A local transmission shop should be able to scan it and see what the issue is
Jul 26, 2017 at 3:15 AM
FRED MCGEE
why does overdrive light flashes on and off
Dec 21, 2020 at 1:16 PM (Merged)
If the OD light continues to flash, the computer has identified a problem within the system. What you need to do is have the computer scanned for codes.
Most parts stores will do it for free.
Let me know what you find.
JFTOATES
the overdrive(lockout) light on the dash comes on after about five minutes of run time then flashes for as long as the car is driven. Is this a modual going out or a problem with the transmission?
Hi:
It could be a module. Have you had the computer scanned for codes?
HONDATECH74
  • 34 POSTS
is the o/d button loose?
RON1949
The overdrive light on the dash of my 1998 Ford Explorer is flashing on & off. What could be the problem?
WRENCHTECH
  • 20,761 POSTS
That is an indication that the transmission control system has identified a malfunction and stored a code. You will need a professional scan tool to be able to retrieve the stored TCM codes.
MTABOR
i was driving on freeway, and noticed the o/d off light flashing, i didn't notice anything weird/different, until i was coming to a stop. the first stop light i kinda thought it was just me; i was wearing flip flops and maybe my foot slipped or something. then at the next stop sign, it was almost kind of like a hesitation? our speedometer was discovered last weekend is 5 mph off. please help.
Dec 21, 2020 at 1:17 PM (Merged)
Good afternoon,
With the light on, there is a code stored in the system. In most cases, it is the torque converter that is the issue.
https://www.2carpros.com/articles/automatic-transmission-problems
The first thing I would do is change the fluid and filter. It may be starving for fluid from the filter being partially clogged.
MTABOR
i assume you are talking about the transmission fluid?
That is correct. Sorry, I forgot to mention that.
RAMCCULLOUGH311
why would the over drive off light just start blinking out of no where?
The computer has identified a problem. The light's flashing is telling you to have the computer scanned to identify where the problem is coming from.
DORSEYBLACK
I have a 1996 Ford Explorer 2-wheel drive 4 cylinder. As I am riding, once I am riding a few miles, the o/d off...overdrive off light starts to blink on and off. I can feel the truck sort of jerk right before this starts. Once the engine is turned off, I can again ride for a while and then it happens again. This has been occurring for about 2 weeks now.
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to get a scan done as this is a fault light, there will be a code set that will indicate where the problem will lie, start here.
mark (mhpautos)
ROBERTWILEYJR
Transmission problem
1995 Ford Explorer 6 cyl Two Wheel Drive Automatic 135k miles
my overdrive light keep blinking on my 95 explorer, it wont shut of, I disconnect the negative cable and it stay of for five minute, what do i need to do to repair this problem. also here are the scan code 646 on 1 & 2 Gear and 647 for third gear, what do these code mean?
RACEFAN966
  • 5,029 POSTS
Well with everything that I can find it could be the overdrive button or the torque converter is also a very common problem. What I need you to do is see if you can the trouble codes from the transmission. What you need is a paper clip and a test light to get codes. Use the pic below to hook up. The top pic is what to use. Hook the test light up how they show the meter hooked up. Now they show a jumper wire from the self test input (single small connecto) to the signal return on the larger test connector that is where you put the paper clip so that they are connected. Now turn key on engine off and the test light will start to blink. It will blink once short pause then blink twice and longer pause then it will go to the next code. This is a code a 12 it means it is going into self test mode. Now with the rest of the blinks just count them in the same way get back to me on what you find.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_83.jpg
ROBERTWILEYJR
RACEFAN966
  • 5,029 POSTS
These codes are indicating a transmission problem. Now there is a couple of tests for you to perform if you like. One is a drive test that you can do and then pull the codes again to see what is still present.
The other is a pin test. I say clear the codes and then do the drive test and see what codes come back. Here is how the drive test is to be done ok.
First warm the engine up to normal operating temp. Ensure that the transmission is full. Now put the truck into into drive and press the O/D switch to turn off overdrive. Your light should be on. Now get up to 40mph and hold it there for 15 sec (30 seconds if you are 4000 ft elevation or more). Now push the O/D button to go into overdrive and accel to 50 mph and hold for 15 sec (30 if above 4000 ft). Now while maintaining your speed use your other foot and light press on the brake pedal (just enough to make the lights come on) now maintain 50mph for another 5 secs. Now bring the truck to a stop for 20 seconds while keeping it in drive (like you are at a stoplight for 20 seconds). This driving cycle need to be done 5 times then we need to see what codes come back. If the codes come back then you will need to have a digital multi meter so we can do some pin tests at the transmission wire harness ok. Let me know how it goes.
MITCH M
1999 Ford Explorer 4x4 auto trans v6 100,000+ miles.
The overdrive light flashes from time to time on vehicle. When it is flashing the transmission down shifts hard and up shifts same. there are times you feel a jerk or bump much like a stall torque. Fluids have been changed and was told a transmission module. Help.
COOLBOY0715
I am have the same problem Mine is a 2000 V6 4X4 and i just had it put on the computer and they said it was Torque Converter Control was the code it was reading but i have no clue what that means.
A MURPHY93
I have a 2000 Ford Explorer 4.0 4x4. I was doing some trail riding today didn't give me any problems but then I get back on the highway and I started to notice it wouldn't shift until 3,000 rpm's, then it stopped shifting at all. drove it home in 2nd gear and the overdrive light started flashing has 2000 xxx miles on it I'm not sure what to do; solenoid change or just replace the transmission? Not sure what to do. never gave me any problem at all still pulls strong in 1st and second. I don't want to waist the money on solenoids if it wont fix it. they are like $60.00 a piece for those. any help would be cool.thanks
Good afternoon,
This issue is caused mostly by the torque converter. It may either be stuck in lock up or will not lock up. When that happens, the light will flash and disable converter commands.
Are there any codes set in the system?
The first thing I would do is change the fluid and filter. Check the magnet in the pan for any metal or debris.
JEANEH
  • 5 POSTS
1996 ford explorer 4x4 69,000 miles
check engine light came on and overdrive light keeps blinking. won't shift into high gear. all fluids are fine. was shifting perfect before.
INDYUKE
  • 416 POSTS
Since the check engine light came on, the vechicle's computer has set a code or several codes. Are you able to scan the computer for codes.
JEANEH
  • 5 POSTS
how do you scan computer
JEANEH
  • 5 POSTS
took explorer to aamco for free computer scan. they said input and output sensors on transmission weren't even and they also received signal from transmisson selinoid. they want to take it out and take it apart and check it out. don't have the money for that. any ideas ??
INDYUKE
  • 416 POSTS
You mentioned that the trannsmission was shifting fine before. Did anything unusual happen while driving that would indicate a problem just before the check engine light came on and the overdrive light started flashing. Strange noises? Tranny overheating? Towing a large load? Trouble going into 4x4? It seems unlikely that a vehicle with barely 70,000 miles would blow a tranny.
You may have a bad shifting solenoid.
JEANEH
  • 5 POSTS
i've had the explorer since may 2006. i've never towed anything or driven it in 4x4. nothing seemed any different no noises nothing. i drive it mostly to work and when i can i visit my family who lives two hours away. i basically drive it like a car.
HEAVYDUTY
  • 60 POSTS
chances are that the transmission was slipping and the computer put it in safe mode, it will probably need to come out to be fixed...I recommend an actual transmission repair shop look at it
JEANEH
  • 5 POSTS
does anyone know if you can change the shifting selinoid without removing the transmisson ? not sure where the selinoid is. thanks
