Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chrysler
Sebring
Drivetrain
Bearing Hub
Replace/Remove
Axle nut size needed?
2002 CHRYSLER SEBRING
240,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
BRINX333
MEMBER
1 POST
FOLLOW
I'm replacing the driver hub assembly; I need to remove the Axle nut on the Driver side but don't know what size socket to get for it.
Jul 22, 2023 at 5:43 PM
CERTIFIED EXPERT
That is a tough question to answer because they used different ones. Also, when replaced, the new ones are usually different.
The manual only provides the torque specifications, which I attached below. As far as the nut size is concerned, it is going to be approximately 32mm.
Let me know if that helps.
See pic below.
Image (Click to enlarge)
Jul 23, 2023 at 6:54 PM
