my number two cylinder is not firing. I have checked the wiring and coil pack with an ohm meter. All is good. I replaced the coil pack wiring harness, new plugs, new injectors as well. I pulled the plug and it gets spark. Also, it was wet.
Things I have done;
swapped coil packs, swapped plugs, replaced wire harness, ohm check all coil packs and wire harness and ignitor pack.
Things I have done;
Dec 15, 2016 at 8:07 PM
