Number eight spark plug not firing
1988 CHEVROLET 1500
625,340 MILES • 5.7L • V8 • 2WD • AUTOMATIC
GLIDERBOY19
  • 6 POSTS
I changed the distributor, wires and plugs after having an intermittent skip in the engine. The old distributor was in bad shape. After completing the install I cranked the engine and the skip was still there all the time. I checked the compression on #8 and found it good. Tested with a separate plug and plug wire and found no spark at #8. Suspect the ESC or ECM. What might be the problem?
Jul 22, 2019 at 11:55 AM
Good afternoon,
What was the compression?
If you installed a new distributor and have no spark to 1 cylinder, then something is wrong with the distributor. What kind and where did you buy it?
The ECM has no involvement in spark to number 8.
Jul 22, 2019 at 12:32 PM
GLIDERBOY19
  • 6 POSTS
Bought the new distributor at O'Rielly auto. The old one did the same thing.
Jul 22, 2019 at 1:01 PM
Did you set the plug on the manifold to be sure there is no spark?
It does not make sense for not having spark on 1 cylinder with all the resr firing.
Is the wire grounding anywhere?
Jul 22, 2019 at 1:05 PM
GLIDERBOY19
  • 6 POSTS
Compression on #8 was 150lbs. This engine has 92,000 miles on it. The problem began as intermittent.
GLIDERBOY19
  • 6 POSTS
Tied the test plug to a good ground. Got the same response.
Jul 22, 2019 at 1:07 PM
Did you change the cap and rotor?
Jul 22, 2019 at 1:11 PM
GLIDERBOY19
  • 6 POSTS
Yes. Changed the rotor and cap. Also new distributor module.
Jul 22, 2019 at 1:21 PM
A new module should have come with the distributor.
None of this makes any sense. You have changed all the components with no result in spark for 1 cylinder.
Does the shaft in the distributor have any lateral play?
Jul 22, 2019 at 1:24 PM
GLIDERBOY19
  • 6 POSTS
No.
Jul 22, 2019 at 1:30 PM
Okay, something was missed somewhere.
Start over and recheck everything. Check the wire with an ohmmeter and tell me the resistance.
Jul 22, 2019 at 1:34 PM
