Noted surge and bucking
2000 DODGE AVENGER
211,500 MILES • 3.2L • 4 CYL • 2WD • AUTOMATIC
DODGEMAN58
  • 6 POSTS
While driving at 45 mph on level road and a slight deceleration the motor will surge an buck. Why so?
Oct 27, 2018 at 1:31 AM
It sounds like it could be misfiring. Can we run the codes to see what comes up? Here is a guide:
Oct 28, 2018 at 5:17 PM
DODGEMAN58
  • 6 POSTS
Ken. I stopped by an auto shop and a code reader will not get codes as the check engine light is not on. No codes to get. Thoughts?
Thanks
Oct 31, 2018 at 2:19 AM
I would start with a good OEM part tune up and service the throttle bore as well. Here are two guides that will help you get started:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
and
https://www.2carpros.com/articles/engine-hesitates
Oct 31, 2018 at 11:29 AM
DODGEMAN58
  • 6 POSTS
Thanks Ken. Will take your advice. Let you know asap. Dodgeman58
Oct 31, 2018 at 8:05 PM
Please do :)
Nov 1, 2018 at 12:58 PM
DODGEMAN58
  • 6 POSTS
Ken. I changed plugs and wires. Was not the solution. What do you think about the vehicle speed sensor casing the problem?
Dec 21, 2018 at 1:43 AM
It would through a code if the sensor was causing problems. It sounds like the MAP or clogged fuel filter. If the MAP becomes weak it will give a false reading to the computer without setting a code. Here are the locations for both below with a guide to walk you through the filter change:
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Dec 22, 2018 at 12:11 PM
DODGEMAN58
  • 6 POSTS
Thanks Ken. Will change both and let you know.
Dec 22, 2018 at 7:27 PM
Dec 24, 2018 at 11:31 AM
DODGEMAN58
  • 6 POSTS
Ken. I changed the fuel filter and MAP sensor. Still the same. The problem is when going down hill the car is bucking, no load on the motor. What mechanism slows the car down when on cruise control going down hill? done does not increase. Does the transmission brake? That is what the symptom feels like. Thanks
Jan 15, 2019 at 7:38 PM
Yes, the transmission does hold the engine to the car when decelerating. Have you serviced the transmission recently? If not here is a guide to help walk you through the steps:
Can you please shoot a quick video with your phone so we can see what it is doing? that would be great. You can upload it here with your response.
Jan 16, 2019 at 2:00 PM
