Good morning,
Yes it is possible.
Did you verify voltages at the alternator to be sure you have available power for the alternator to work?
what is the voltage at the battery with the engine running?
I attached a diagram for you to view. the TIPM supplies power to the PCM for the field controls for the alternator. make sure there is battery voltage to the two terminals listed with the key on engine off.
Jan 2, 2019 at 8:53 AM
