not starting when cylinder head is fitted
1999 TOYOTA HARRIER
V6 • TURBO • AUTOMATIC
LYTON
My Toyota Harrier once overheated and then I gave the cylinder heads to the engineers they skimmed and reconditioned the cylinder heads.When I then fitted the heads, the car is not starting at all.What could be the problem?
Nov 29, 2014 at 11:39 AM
JOHNNYT73
  • 924 POSTS
First check around that everything is plugged in, cam sensor, crank sensor, ECT sensor, all ground straps are connected. After that The first thing you may need to is make sure your timing is set correctly at the timing belt.
Nov 29, 2014 at 1:10 PM
LYTON
can u do me a favour to tell me where the camshaft, crankshaft and ECT sensors are.Please Please I really do not know.Thanks in advance
Nov 29, 2014 at 1:25 PM
JOHNNYT73
  • 924 POSTS
If you didnt bother to check timing when installing your head. Then I am willing to bet that is your issue. Here is a photo of sensor locations on a 1999 camry 2.2L
Nov 29, 2014 at 1:43 PM
