not starting, occasional engine off
2007 TOYOTA AVENSIS
100,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
KUNLELORDS
The car always off immediately after starting. It sounds as if it has started, but the rev will drop to zero immediately, except I press the accelerator pedal. Even at that it will still drop, until I depress the brake and engage the gear. Sometime the engine do stop while driving. Also It consumes fuel, the claimed consumption for highway is 6.6 ltr/100km. But now it does around 12ltr/100km.
Note: I bought this car used about 2 months ago.
Please, I am eagerly expecgting your response and advice. Thanks.
Dec 20, 2015 at 3:24 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge you may need a pro to check fuel pressure as it may need an adapter.
Dec 20, 2015 at 8:38 AM
