Not starting, has power, new battery
2015 DODGE DART
57,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
B@CONATOR6
  • 16 POSTS
Tried to start my car, it didn't turn over or even make a noise. it is giving me a lot of warnings. like; service power steering, airbags, brake system, check fuel cap. pretty much everything. also i tried to turn my radio on and it says the key must be in the run position. and it is in the run position. i checked some fuses and they all seem fine. i'm stumped.
Feb 21, 2020 at 11:21 AM
Good afternoon,
This sounds like a low battery and there is not enough voltage to let everything come on.
You need to test the battery for the correct voltage.
I would also clean the cables as well.
Feb 21, 2020 at 12:12 PM
B@CONATOR6
  • 16 POSTS
I checked the battery it's good, I bought it less than a month ago. All connections look good as well.
Feb 21, 2020 at 12:16 PM
B@CONATOR6
  • 16 POSTS
https://youtu.be/41KyeScM1mU
Feb 21, 2020 at 12:17 PM
What was the battery voltage?
Feb 21, 2020 at 12:21 PM
B@CONATOR6
  • 16 POSTS
12.63.
Feb 21, 2020 at 12:22 PM
Okay, I attached a wiring diagram for you to view. Check the highlighted fuses. If they are good we will need to do some testing. This system has 2 relays for the starting system.
Feb 21, 2020 at 12:30 PM
B@CONATOR6
  • 16 POSTS
Well all the fuses look good. the bigger black ones the relays I believe I am unsure about and don't know how to test them.
Feb 21, 2020 at 12:45 PM
You need to test for power at the fuses I highlighted. This is not a visual test, it is a power test with a test light.
We will need to test for powers at the relay.
Feb 21, 2020 at 12:51 PM
B@CONATOR6
  • 16 POSTS
With is an altimeter? And how do I go about that? I'm not very knowledgeable on this matter sorry.
Feb 21, 2020 at 12:55 PM
You need a test light, not a voltmeter. I will attach a guide for you.
You can get one at a parts store. they are cheap.
Feb 21, 2020 at 1:01 PM
B@CONATOR6
  • 16 POSTS
So I didn't get any lights for those fuses. What next? Sorry for the delay I had to go get the test light. Should the key be in the run position when testing?
Feb 21, 2020 at 2:39 PM
Yes, it should be in the run position.
Feb 21, 2020 at 2:50 PM
B@CONATOR6
  • 16 POSTS
Okay, yeah I got light on all those.
Feb 21, 2020 at 3:27 PM
Okay, I need you to go to the starter motor. There is a big wire on the solenoid from the battery and a small wire as well. Test for power on the small wire with the key in the start position.
Feb 21, 2020 at 3:31 PM
B@CONATOR6
  • 16 POSTS
Not sure which one.
Feb 21, 2020 at 3:45 PM
Picture attached.
Feb 21, 2020 at 3:53 PM
B@CONATOR6
  • 16 POSTS
Sorry, but that picture really didn't help me.
Feb 21, 2020 at 3:56 PM
The starter is down where the engine and transmission come together. It is at the front side of the motor about halfway down.
https://www.youtube.com/watch?v=XutnAqm4J8I
Feb 21, 2020 at 4:05 PM
B@CONATOR6
  • 16 POSTS
Wow, I think I'm in over my head. I'm pretty sure it's the starter, I'm broke and have no knowledge or equipment to do that kind of work. I really appreciate your help.
Thanks again.
Feb 21, 2020 at 4:31 PM
You are welcome.
Always glad to help.
Feb 21, 2020 at 4:35 PM
