Hello, so the engine tries to crank over but only clicks sometimes? Is that a correct description of the issue?
Ill post the wiring diagrams for the Starter motor circuit, but it sounds like either there isnt full battery voltage reaching the starter, or you have a bad ground. The starter motor pulls hundreds of amps when cranking, if the ground path of the vehicle has an issue, there is no return path for all that current. Or you got a new bad starter. That happens all the time now.
Feb 11, 2026 at 7:01 PM
