no crank no start
1999 SATURN SL2
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
PERRY THOMAS
turn key on dash light work, battery 12.90 volts, but will not turn over engine and crank. been doing fine then this. did this once before about six months ago. drove, parked went store came out same then called road service they came and it cranked no problem. this time has not done anything in twenty four hours. I check wires, starter all tight what can it be? all fuses good.
Oct 23, 2016 at 1:50 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like a bad starter common symptoms for those. Lightly tap on the starter while trying to start it. Most likely it will start up.
Oct 23, 2016 at 2:09 PM
