It was running fine on tick over with a very minor hunt, next day was ticking over and stopped just as if had been turned off and then I started straight up with no problem. The following day would not start there was no power to the stop solenoid on the fuel pump when I fed a separate 12v to solenoid it started straight up after some time the start relay in the passenger footwell stopped operating but you can hear clicking of the cold start solenoid in the engine bay that consists of feed from the relay in the footwell that in turn should feed the solenoid that connects the two wires to complete the circuit if i unbolt. The two wires and join them together it would short out I have tried to eliminate components to try and find the issue there are no blown fuses. I am somewhat at a point where it is very annoying and would appreciate any advice towards resolving this issue. I thank you in advance.
Kind regards
Kind regards
Nov 13, 2024 at 4:22 PM
