Not shifting down
2000 CHEVROLET S-10
215,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
RJRT
  • 7 POSTS
After the truck is warmed up when you get down to about 20 mph the truck doesn’t want to shift down to first on its own.
May 21, 2020 at 11:38 AM
Good afternoon,
Does the transmission up-shift okay?
This sounds like a valve body issue.
https://www.2carpros.com/articles/automatic-transmission-problems
when was the last time you changed the fluid and filter?
Is the check engine light on?
May 21, 2020 at 12:09 PM
RJRT
  • 7 POSTS
Yes, it shift up fine. it’s just 0 to 20 that it has trouble.
May 21, 2020 at 12:25 PM
RJRT
  • 7 POSTS
I am not sure about when the filter was changed, but it had new fluid a couple months ago.
May 21, 2020 at 12:29 PM
Do you mean from 20 to 0?
Did you change the fluid and filter?
May 21, 2020 at 12:30 PM
I would still drop the pan and change the fluid and filter.
May 21, 2020 at 12:32 PM
RJRT
  • 7 POSTS
Yes, I meant 20 to 0.
May 21, 2020 at 3:40 PM
Okay, I would start with changing the fluid and the filter. Look for any debris in the pan or on the magnet on the bottom of the pan.
If that does not work, most likely the valve body will have to come down and gone through.
May 21, 2020 at 3:42 PM
RJRT
  • 7 POSTS
Okay, thank you. I will start with that.
May 21, 2020 at 4:01 PM
You are welcome.
Always glad to help.
May 21, 2020 at 4:06 PM
