Not much power
2017 SUZUKI VITARA
18 MILES • 4 CYL • TURBO • 2WD • MANUAL
ANEES MOHAMMED
  • 5 POSTS
My car had a huge accident last year. I repaired the car from a local workshop. Now my car does not have much power that i used to drive. It is difficult to overtake by using my car. No one knows why. Injector, inter-cooler, radiator all are new. Can you help me to rid of this problem?
Dec 23, 2018 at 5:19 PM
I have no idea the extent of the damage and to what portion of the vehicle, but anytime someone experiences a loss of power, I always question if the exhaust or catalytic converters are damaged, restricting flow, or damaged in some way. Have you checked and confirmed the system wasn't damaged in the accident? It isn't something people normally check.
Here is a link that shows how to check. Do this and let me know the results. If the converters weren't replaced, they could have been damaged in the accident and partially plugging the exhaust flow. Also, let me know if the check engine light is staying on,.
Let me know what you find,
Dec 23, 2018 at 7:02 PM
ANEES MOHAMMED
  • 5 POSTS
There is no physical damage for exhaust pipe.
My car is Vitara Brezza.
Dec 23, 2018 at 7:35 PM
ANEES MOHAMMED
  • 5 POSTS
Is there any chance for the injectors changed by repair shop by fault one?
Dec 23, 2018 at 7:37 PM
ANEES MOHAMMED
  • 5 POSTS
What happens if injectors of one car is changed with injectors of another car?
Dec 23, 2018 at 7:38 PM
Many things can happen because not all injectors are the same. It could get too little or too much fuel, run poorly, not run at all.
Dec 23, 2018 at 8:03 PM
ANEES MOHAMMED
  • 5 POSTS
Inlet manifold was broken and it was glued entirely by fiber experts. Can it be a problem?
Dec 24, 2018 at 7:37 PM
If there is a leak or something isn't true and not mounting properly, yes. However, that would cause an engine vacuum leak. Take a look through this link. Try what it suggests and see if you find a vacuum leak.
Let me know
Dec 24, 2018 at 8:18 PM
