Not accelerating past 5 mph
2003 VOLVO S60
185,000 MILES • 4WD • AUTOMATIC
KRHODES
Two days ago my car would not go past 5 mph or 1,000 RPM's. When I got it back into the driveway, the battery acted like it was dying. The next day it ran perfectly fine. When we went to take it in, again it would not go past 5 MPH or 1,000 RPM'S
Jan 5, 2020 at 7:49 AM
JIS001
  • 3,412 POSTS
If the battery light started coming on then I would recommend checking your alternator. If the voltage drops below 10 volts the electronic throttle will stop responding. Here is a repair guide on checking the alternator:
Let us know what voltage you are measuring when it starts to act up.
Jan 6, 2020 at 12:31 AM
KRHODES
It is now not turning on at all, the warning message says that the key I've been using isn't programmed to the car.
Jan 6, 2020 at 3:02 AM
JIS001
  • 3,412 POSTS
Do you have another key you can use.
Jan 6, 2020 at 7:02 AM
