not going into first and second gear
2006 ALL OTHER MAKES ALL OTHER MODELS
121,000 MILES • 1.6L • 2WD • MANUAL
KKYLELEE
i just changed the clutch bought a clutch kit but the is still not going into first and second gear it is an issue what is the problem and how do i solve it and fix it please help
Aug 4, 2015 at 10:25 PM
HMAC300
  • 48,601 POSTS
if i's acar check for a bad cable or shifter or internal trans problem.
Aug 5, 2015 at 6:25 AM
KKYLELEE
yes it is a car tata indica 1.6 but the problem comes and goes you say its internal transmission issues
Aug 6, 2015 at 5:01 AM
HMAC300
  • 48,601 POSTS
check all your adjustments like cables worn out or broken, or shift rods bent out of adjustment because we have no info on this car this is about all I can tell you
Aug 6, 2015 at 6:02 AM
