P0116 - Engine coolant temp sensor circuit range/performance - could cause your running issue
P0558 - Brake booster pressure sensor circuit high - likely not related.
P0339 - Crankshaft position sensor "A" intermittent - can cause all sorts of running issues
P0594 - Cruise control servo circuit control open - likely not related
The images below address testing the coolant temperature sensor. I will address the CPS in the next post.
Sep 10, 2018 at 4:02 AM
