Not getting fire from distributor
1997 CHEVROLET TRUCK
144,000 MILES • 5.7L • V8 • RWD • AUTOMATIC
DAVID WARWICK
I am getting fire to my crank shaft position sensor ignition module and coil, but I am not getting fire out of the distributor to spark plug.
Aug 5, 2016 at 1:05 PM
HMAC300
  • 48,601 POSTS
if you get fire to the distributor then it is either a bad rotor or distributor cap so check those.
Aug 5, 2016 at 1:16 PM
DAVID WARWICK
Brand new cap and rotor.
Aug 5, 2016 at 1:23 PM
RIVERMIKERAT
  • 6,110 POSTS
Pull the coil wire and stick a well-insulated screwdriver in the end. Hold it about half an inch or so from a ground as someone cranks the engine. No spark=bad coil or wire. Check it with a known good one.
Aug 5, 2016 at 2:45 PM
