No fuel or spark or fuel injector pulse
1995 MITSUBISHI ECLIPSE
150,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
JOSH CONNER2
not getting fuel or spark or fuel injector pulse.
Nov 29, 2017 at 3:09 PM
Check the ASD relay under the hood. I believe it is mounted with others on the passenger side of the vehicle. Also, if I recall (it has been awhile) it will be the second one closest to the firewall.
Nov 29, 2017 at 6:07 PM
JOSH CONNER2
The ASD relay has power .
Dec 3, 2017 at 2:01 PM
To me it sounds like you have a crankshaft angle sensor not generating a signal of the computer. This can be because you have a broken timing belt or the the sensor has gone bad. Here are some guides and diagrams below to help us get started in fixing the problem.
and
https://www.2carpros.com/diagrams/mitsubishi/eclipse/1995
and this one will give you an idea of what you are in for when doing the job.
Dec 5, 2017 at 3:21 PM
