Just to add, dark green wire with orange tracer is primary voltage to the coil, check for voltage on that wire with engine cranking. Your fuel injectors get voltage on the same color wire. That voltage comes from the asd relay. If the computer doesn't ground the asd relay, the usual cause is the computer didn't see the proper cam and crank signals.
Battery has a full charge? Are there any applicable trouble codes? An obd2 code reader, sometimes, does come in handy. sometimes there are no codes, so an obd2 code reader isn't a cure all. It's just one tool among many.
May 22, 2014 at 2:27 PM
