Not clearing CCM code
2003 JAGUAR X-TYPE
144,000 MILES
KEN SCHERR
How can i get my car to clear the comprehensive component monitor? I have driven the car over 500 miles and still wont clear.
May 15, 2020 at 12:40 PM
I looked this up and found the following. First, it indicates there isn't a specific drive cycle for the X-Type engine, but there is for the transmission. Take a look and let me know if any of this helps.
__________________________________________
COMPREHENSIVE COMPONENT MONITOR ENGINE MANAGEMENT DRIVE CYCLE
To avoid unnecessary complexity, a single comprehensive engine management drive cycle has not developed for X-TYPE. Refer to the individual DTC for specific drive cycle I monitoring conditions.
COMPREHENSIVE COMPONENT MONITOR TRANSMISSION DRIVE CYCLE
The Comprehensive Component Monitor transmission drive cycle will "check" all transmission system components:
1. Engine and transmission at normal operating temperature. Ignition OFF; ensure that SPORT mode is NOT selected.
2. With gear selector in P and the ignition ON. Check gearshift interlock by attempting to move selector without pressing the brake pedal. Verify P state illumination.
3. Press and hold the brake pedal. Move the gear selector to R. Verify R state illumination.
4. Set the parking brake. Press and hold the brake pedal. Attempt to start the engine. The engine should not start.
5. Move the gear selector to N. Verify N state illumination. Start the engine.
6. With the hand brake set and the brake pedal pressed, move the gear selector to the remaining positions in the J-Gate (D, 4, 3, 2) for five (5) seconds each. Verify the state illumination in each position.
7. Move the gear selector back to 4. Verify 4 state illumination.
8. Move the gear selector to D. Verify D state illumination.
9. Move the gear selector to N. Verify N state illumination.
10.Select R, release the brakes and drive the vehicle in Reverse for a short distance.
11.Stop the vehicle.
12.Select 2 and drive the vehicle up to 65 km/h ( 40mph ). Hold 65km/h ( 40mph ) for a minimum of five (5) seconds.
13.Select 3 and hold 65 km/h ( 40 mph ) for a minimum of five (5) seconds.
14.Select 4 and hold 65 km/h ( 40 mph ) for a minimum of five (5) seconds.
15.Select D and accelerate to a minimum speed of 80 km/h ( 50mph ). Hold 80 - 129km/h ( 50 - 80 mph ) for a minimum of 1.7 kilometers (1 mile).
16.Stop the vehicle; do not switch OFF the engine.
17.Use WDS Datalogger TOTAL NUMBER OF DTC SET' to ensure that transmission DTC monitoring is complete.
Let me know,
May 15, 2020 at 8:55 PM
