It does have a load detector. If you take a look at the attached pic, they show the entire charging system. I had to cut the pic in half to make it readable. I did overlap them.
If you look on the pics, I highlighted ELD to help you find it. I also highlighted where it attached at the PCM.
If you find it is bad, here are the directions for replacement. The remaining pics correlate with the directions.
2010 Honda Civic L4-1.8L
Removal and Replacement
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Electric Load Sensor Service and Repair Removal and Replacement
REMOVAL AND REPLACEMENT
ELD Replacement
1. Remove the ECM/PCM. See: Engine Control Module > Removal and Replacement
2. Remove the under-hood fuse/relay box. See: Fuse Block > Removal and Replacement > Under-Hood Fuse/Relay Box Removal/Installation
3. Remove the screw (A).
pic 3
4. Turn the housing over, then remove the screw (A).
pic 4
5. Turn the housing over again. Using two flat-tip screwdrivers, release the tabs (A), and pry up the fuse/relay box base (B) from the fuse/relay box housing (C).
NOTE: Make sure the terminals (D) are not bent or damaged.
pic 5
6. Remove the ELD (A).
7. Install the parts in the reverse order of removal.
pic 6
_____________________________
Dec 23, 2020 at 9:39 PM
