Noise coming from the front of engine
2003 DODGE DURANGO
164,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
FREE_FORD
There's a high pitch whistling or whining sound coming from the front of the engine. When I push on the accelerator it doesn't go away, it just goes a little quieter to let it off the gas, it gets loud again very loud.
Mar 6, 2022 at 11:04 AM
BORIS K
  • 836 POSTS
It sounds like you might have a problem with the serpentine belt or tensioner bearing.
A quick check would be to remove this belt and start the engine, see if the noise is gone.
Here is a good video:
https://youtu.be/AEUe6uKxTv8
Video on a V6 engine.
https://youtu.be/YMB_xpr0Emg
Some good guides.
https://www.2carpros.com/articles/how-a-serpentine-belt-works
https://www.2carpros.com/articles/replace-serpentine-belt
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
Please let us know how you get along.
Cheers, Boris
Mar 7, 2022 at 9:02 AM
SQM
  • 6,383 POSTS
This could be due to a pulley or the serpentine belt.
The belt noise can change frequency with the engine speed.
One thing you can try is to spray belt dressing on the belt while the engine is idling. If the noise changes, then you will know the issue is the belt.
Here is a helpful article:
https://www.2carpros.com/articles/car-squeaking-noise
Can you possibly upload a video, so we can hear the noise? It will be helpful.
I have attached the belt inspection procedure below.
Thank you.
Mar 7, 2022 at 9:21 AM
