noisy engine overheating and symptoms no longer apparent
2004 NISSAN MAXIMA
236,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
H.MANIAPOTO
When I started my car my engine made a loud rattling sound. I tuned it off and the rattle became intermittent and the temperature gauge came on after a couple of miles while driving it to the repair garage.
The garage said engine was beyond economic repair so I took it home and parked it up for about a four to five months while I looked for a reconditioned engine for it.
However, when I went back and started it again the noise had stopped and the engine no longer overheats. I have run it for over thirty minutes without any of the symptoms recurring.
I checked the oil and yep, the tell-tale signs that were there when I parked it up were still present. yellow goo on oil filler cap and on the dipstick.
However, running the engine with the radiator cap off produces no visible bubbles although I did have to top-up the coolant reservoir which was low. After all the standing time the only thing that failed was the battery went flat, but was all good after I charged it up.
Can you explain why the engine problem is not occurring now, and what would cause it to disappear now? I am really puzzled.
Oct 15, 2017 at 5:27 PM
MHPAUTOS
  • 31,937 POSTS
If you get the engine up to prolonged normal operating temperature you may well find the problem is back, the sure way to prove this is with a head check, this is a simple and quick chemical test for exhaust gasses in the cooling system, most mechanics can do this test while you wait. a positive test will be a head or gasket problem.
Oct 16, 2017 at 4:32 AM
H.MANIAPOTO
Thanks MHPAUTOS. will get that done as soon as possible.
Oct 16, 2017 at 4:36 PM
Here is the test in case you want to perform it yourself.
Please let us know what you find. I'm interested to see what it is.
Oct 17, 2017 at 6:05 PM
